Vantage Audio Technics SL-1210 PCB upgrade & PSU
I have posted elsewhere on AoS my very favourable impressions of the VA bearing and platter upgrades for my SL-1210. I was thus very much looking forward to hearing how the PCB upgrade and bespoke PSU sounded. I was not disappointed. Doubly so since Richard and his son very kindly dropped in yesterday to install everything for me. Not because it isn't suitable for an owner upgrade but because that's the sort of customer service VA give :)
The PCB upgrade consists of replacing all the capacitors with modern tight spec versions and "re-working" the earth tracks on the underside of the board. The PSU is a sizeable box with a high quality flying DC lead with lockable 2.5mm plug and integral sensor. The lead plugs into a chassis socket in a bespoke plate that replaces the stock metal cable exit plate. The plate also carries a 4mm chassis socket connected to the PCB earth for optional connection to the preamp earth binding post.
We listened to a few tracks with the stock PCB and my TimeStep PSU and then while I looked the other way Richard dismembered the deck and dropped in and connected up the new board and PSU. The deck fired up on first switch on :thumbsup:
There was an instant and definite improvement (not just a difference). Bass was better defined and went down lower (actually "felt" some of the kick drum as opposed to just hearing it) and was tighter controlled but the biggest difference was with timing - notes started and particularly stopped with better definition - particularly noticeable with percussion where "double drum taps" became obvious whereas before it just sounded like a single stroke. This translated into better dynamics and range. Soundstage tightened up with much better focus of instruments and voices in space.
Reading back through my previous posts on the VA bearing and platter upgrades I note my comments are very similar so it seems the VA "philosophy" is step-wise process to improve platter rotation control and thereby improve information retrieval and timing.
IMHO Vantage Audio offer a very cost-effective upgrade path for the SL-1210 which delivers tangible improvements in sonic quality and musical enjoyment and superlative customer service.
Steve
