Put the cable in the box with the cat..
Ah!... Schrodinger's Cat I think you must mean!
Good book, as long as you don't mind your head having corners by the time you've finished reading it!
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
Yes indeed!
Alex
Amplifier: Rega Brio R. Speakers: Spendor SP1. Cables: Various, mainly Mark Grant. Please see "about me" for the rest of my cr@p! Gallery
Well... that might happen. And it might not. The cat might not be in the box. Or the cat could BE the box! And if no-ones there to hear the cat, does the cat exist?
Or is the cat a corkscrew gathering the malingering electrons and negative charges and forcing them to join the procession?
I'm fucked if I know!
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
The cable might be good,the cable might not be good...
You are not alone. I have a strong electrical engineering background and it still does not make any sense. It is a warble.
The gentleman in that text is referring to forcing the electrons towards the surface of a conductor. A conductor has a property called an inductance and the inductance in the center of a conductor is greater. As the frequency increases the inductance takes greater effect and the current experiences greater opposition, forcing the electrons towards the surface of the conductor to flow. But when the current flow ceases eveything goes back to normal. You do not open up new frontiers to the electrons by applying that so called magic burn in signal.
If one thinks he/she hears a difference by applying that magic burn in signal to a conductor then it is his/her affair. But as soon as one enters into psuedo scientific lecturing then the problem starts. Let's discuss the effects of cable resistance, capacitance and inductance, but if we are going to get down to electron theory let's make sure we have sufficient physics credentials.
However, equipment heating time is real but there are no magics in it. It is as simple as the components reaching to a stable tempereture and consistent functioning. I don't start testing as soon as I turn my scope or oscillator on. I have a minimum heat up time of half an hour.
Cemal.
Yes!... Thank you!
I was particularly impressed by this bit... But NOT favourably...
Imagine a high-frequency, high-energy force zipping along the conductor surface in a corkscrew fashion between the conductor and into the dielectric; the malingering electrons and negative charges are then forced to join the procession.
Complete drivel!
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
