Results 11 to 20 of 22
Thread: Moon Gel pads
    Apparently this Moon Gel is exactly the same stuff, just packaged differently. I bet this happens a lot, where a product is repackaged nicely and repurposed. I just can't think of any off top of me head.
    Super-bargain! I've ordered one already, can't lose at that price
    I'm Adrian.
    Make sure you don't loose the cantilever in the the gel by going to deep with it.
    Default Moon Gel pads
    I found this today...
    Onzow zero dust.
    I'm Paul.
    I have used moongel, Zerodust, Blutack and even putty but gave them all up, I could see that each time you drop it onto the gel and lift off it would pull on the cantilever which was of concern, I now use a long Sable artist brush to remove the fluffy stuff and for the hard gunk I use the magiceraser sponge (Amazing stuff) But again must be used very carefully.
    HI-FI SYSTEM:-
    Revox B250 Amp.
    Revox PR 99 mk2 R2R.
    Revox B126 C/D Player.
    Yamaha GT2000 T/Table with Shure MKIV Cartridge and Jeco VN-45HE SAS/R Stylus.
    Bang & Olufsen Beolab18's and the 19 Sub Speakers.
    A/V 5.1 System :-
    Soundsend Wisa box.
    Harmen Kardon front and rear satellite.
    Legend 10.2 Silverback Active Centre.
    Thanks for the heads-up, I will be super careful
    Quote Originally Posted by p147 View Post
    What's a magiceraser sponge Paul, and where did you get it?
    I'm Paul.
    Don't get the Flash ones or shaped ones as they may be impregnated with disinfectant, you just want the plain and simple rectangular one such as these on E-bay :- https://www.ebay.co.uk/itm/10-x-Magi...4AAOSw0gVdkSru
    It is so cheap and a small piece will last a lifetime, If you look under a microscope it is constructed of fibre similar to microscopic Velcro, all you need to do is cut of a piece to fit in a matchbox, rest it on the platter and lower and lift your cartridge 3 or 4 times onto it (DO NOT DRAG) it will leave the stylus polished. Again be very careful and try on a not so expensive cartridge until you feel confident.
    There's plenty of info online and on YouTube.
    HI-FI SYSTEM:-
    Revox B250 Amp.
    A/V 5.1 System :-
    Soundsend Wisa box.
    I'm Paul.
    HI-FI SYSTEM:-
    Revox B250 Amp.
    A/V 5.1 System :-
    Soundsend Wisa box.
