I think I was watching these on eBay, they're in Brighton aren't they? Just get an Uber if necessary.
I'm Dennis.
I strip the speaker cable to the length required to go through the lower posts and into the upper, and tin them so that there are no loose strands which may short out your amplifier.
You can then tighten up and the solid rigid wires will compress under the screw pressure because they are malleable.
Yeh, I missed out on auction, sent him a message saying if winning bidder pulls out etc. Which they did cos they were in Portugal! Says I'll give him £300 cash, he agrees, says he'll bring them to my flat, I did say I would need to hear them working in order to pay cash, he said ok, but then radio silence.
Radio contact re-established. So the binding posts on these oldies can't take plugs? PITA!
Really? I've got a pair of Ref 1.2s in the house ready to go to Tonbridge on Sunday and they take 4mm plugs just fine.
The holes in the ends of the speaker terminals give you a clue. They take plugs.
might have removable caps in the ends of the sockets
