Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Do you have a tatty 1200 or 1210 ?
    I'm Allen.
    Default Do you have a tatty 1200 or 1210 ?
    If you do these look good
    https://www.ebay.co.uk/itm/SL-Techni....c100167.m2940
    Spiffing old chap
    Alex_UK's Avatar
    Looks bloody cheap for the effort that must go into making them. Might buy a 1200 just so I can buy a lilac faceplate!
    Alex
    I'm Allen.
    Quote Originally Posted by Alex_UK View Post
    You big lilac tart
    I have a mint 1200 and a tatty one but I don't see how these work. It says you just take the hinges off and slide it on but how do you do that without removing the arm and so forth?
    He could do with a much better advert.
    I'm Allen.
    If you look at the last image the arm hole is pre cut so it will just drop on with a bit of wiggling
    better be a good wiggler
    yes, I see what you mean now.
    I'm Stephen.
    I have something very similar on mine. I got the seller to do me a custom plate without the pitch slider cutout which I removed. Mine has a shorter lip on the outside (I think it looks better than the deep one).
    IMO it really lifts the aesthetics of the TT. From memory it was about the same price.
    Steve
    Always a little further
    I'm Allen.
    Designed to perfection and precision made, each face plate is built from mild steel, laser cut, CNC folded and welded on all for corners to Aircraft specification, leaving a seamless join.
    Powder-coated with a hard wearing finish, this product offers a durable, long lasting solution, preventing your decks from getting damaged.
    All that for £65 is in my book a bargain
    Quote Originally Posted by worrasf View Post
    Steve
    That does look very classy.
