Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: IC: DCB1 Turbo 1.2A Preamp.
    Bigman80 Guest
    Default IC: DCB1 Turbo 1.2A Preamp.
    Hi all,
    Initial put up as an Interest check.
    I've been giving some thought to putting a BigBottle phonostage PCB inside the DCB1 listed here.
    All is OK in terms of space etc BUT I discovered that when I fitted the extension bars for the Khozmo and the Elna switch, I had to make the holes in the face plate a little bigger to fit the sleeve they require.
    I don't believe I can get a tight enough grip on the Khozmo now, as I need to take the bars out to fit the PCB.
    So, rather than piss about with it and possibly end up no further forward, I thought I'd see if anyone wants to buy this one and I'll make another one to accommodate the changes.
    Inside the Box:
    DCB1 PCB with Dale resistors and Audio Note Tantalums in the most important positions, plus more.
    Obbligato Gold capacitors
    Spotfire wire.
    Elma selector switch
    Toroidy Transformer
    Upgraded MUR120s (I think that's the number lol)
    Silver solder on EVERYTHING
    Running at 1.2A, thus qualifies as the 'Turbo' version and probably as high as you can go with one PCB before it melts lol
    The DCB1 was given the final once over by Firebottle when it was finished.
    As far as preamps are concerned, this has seen off everything that has visited here or been put up against it. It really is a class act.
    The price is set only so its possible to build another to this exact same spec, as I found it to be superior to other specs Steve and I tried.
    £650 collected.
    Delivery is now an option. To be quoted individually!
    I may negotiate a little but not much.
    All response by PM pls.
    I'm Paul.
    I'd love to buy this as just havent found the right preamp for my liking to date. You're in brum aren't you Ollie?
    Sent from my CLT-L09 using Tapatalk
    Current system:
    RPi + Allo Digione
    Beresford Caiman Seg & Dorado powered by 15v Linear PSU
    Transcendent Sound Mini Beast OTL
    Amptastic Mini-1
    Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
    110aH Leisure Battery powers the Mini-1 & Digione
    I'm Adrian.
    This could be ideal for Mikeandvan if his Croft proves to be causing his issues.
    Bigman80 Guest
    Quote Originally Posted by Pepperamip View Post
    Wolverhampton mate. Not far. Welcome to listen to it you can get over this way.
    I'm Ian.
    If it was in a different case with lettering I would have snapped this up, I know from other posts many people like the look thougj
    I'm Paul.
    Quote Originally Posted by Mr.Ian View Post
    I think the case is what sells this over over dcb1 builds I've seen anyway. Shows its all a matter of taste.
    Current system:
    RPi + Allo Digione
    Amptastic Mini-1
    I agree - the external appearence is excellent, and the internal construction is neat and tidy. Good luck with the sale.
    Bigman80 Guest
    A different case!!!! Outrageous lol.
    I'm Paul.
    If I can get the money together before you sell I'll take you up on this.. Have a feeling this will be sold long before then damn it
    Current system:
    RPi + Allo Digione
    Amptastic Mini-1
    I'm AndyElectroNumpty.
    Love mine, whoever
    gets this will enjoy it! glwts.
    Sent from my SM-G950F using Tapatalk
    At the cutting edge of Numptyness!
