Page 1 of 28 12311 ... LastLast
Results 1 to 10 of 271
Thread: Digital Facts and realities?
    Bigman80 Guest
    Default Digital Facts and realities?
    I was given this information via a read me file, just thought I'd share it:
    Digital Facts and realities:
    Most music is in the 50 Hz to 15 KHz range. The Human ear does not hear from the 20 Hz to the 20 KHz range. Almost all speakers, ear buds and headphones will not produce anything outside the 20 Hz to 20 KHz range. The best tape machines will not play anything above the 60 KHz range. So unless something is recorded digitally today 60 KHz is the maximum that can be played back from a Master tape.
    The sampling rate must be double the highest frequency rate. Since all of the above holds true with respect to equipment the industry settled on the 44100 for Redbook Cd’s. They will reproduce a 1Hz to 22.5 KHz range. Beyond most equipment’s capability and the human ears capability.
    The way a digital to analog converter (DAC) works it creates a smooth sine wave no matter what the sampling rate is. Therefor certainly anything above the 48 KHz range is a complete waste of space. The extra room above 40 KHz is used to dither noise. Hence the 44.1 and 48 KHz used on CD and Video. So much for the SACD in the sampling rate respect. A waste of space.
    The Bit rate comparison of 16 bit to 24 bit might be the only saving grace for the SACD. However it has its questionable aspects on a technical level as well. The main function of the bit rate is signal to noise ratio. Keep in mind that we go deaf at the 140 decibel level. 16 bit is capable of 100 DB and 24 bit is capable of 150+ DB. Again most equipment is not capable of over 127 DB level. A well Mastered 16 bit is actually capable of the 120 DB level and is called 20 Bit. Some of the 24 bit is actually 22 bit and the last 2 bits are zeroed out. So the difference between a 16 bit and 24 bit is just about a moot point.
    Mastering is the most important aspect when it comes to sound quality. A well mastered CD is absolutely better than a poorly mastered SACD. And vice a versa. First and foremost in deciding what is the best sounding choice should always be the mastering. Keeping in mind that larger is not better. With all of the above being true in most cases it is certainly a waste. Another consideration is age of the Master tapes with a lot of music. A good master done 20 years ago is potentially superior to a re-master today due to tape degradation.
    Sony is a company with one goal in mind. To make money by keeping sales high. They invented the SACD. With that in mind and all of the above facts as well as numerous testing that has been done showing that 99% cannot hear a difference at all in the SACD compared to a CD the conclusion must be that it is about sales. As far as Sony is concerned. Also if you own an SACD and do not have an SACD player you are actually getting the CD layer when listening to the actual SACD.
    I would think that the perfect media would be 48000-24. Not much larger than a CD and capturing any benefit a 24 bit might have. Which of course is questionable. Certainly not noticeable until you crank it up over the 100 DB range which almost none ever do. Again bigger is not better. The first link is from the makers of FLAC…
    https://xiph.org/~xiphmont/demo/neil-young.html
    http://www.head-fi.org/t/356139/sacd...simply-placebo
    http://users.ece.utexas.edu/~bevans/...ital_Audio.pdf
    I'm Patrick.
    Which bits are the facts?
    Well I cant hear much above 12khz and my ears are still ringing from my last trip to rockworld so I dont worry too much
    Even those that do say there is a difference say it can be subtle and not worth the investment for most people. Im quite happy with the cd standard rate. Most people havent tried or cant hear the difference. There are still debates that the redbook cd version sounds better.
    I havent moved towards higher resolution because I have not been bothered to do it. I was waiting for Neil Young to bring the price down to mass market levels
    I can pick up cds cheaply...Im enjoying the music and it all seems better for me than shelling out for sacd or high res files.
    I dont know how much more information I need and its not been marketed to me properly. I feel that this is mainly because they know im not getting much aural difference for my money
    Hi Oliver
    I would disagree with your comments.
    I know if you disconnected the super tweeters in your pioneers YOU would notice
    Which would suggest your observations are flawed.
    Steve
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
    Bigman80 Guest
    Quote Originally Posted by STD305M View Post
    Hi Oliver
    Steve
    Ah, not my comments mate. This was in a "Read me" file on some music files I was given. Just shared it here to see what people thought.
    And yes, I notice as soon as I turn the Super tweeters off
    Bigman80 Guest
    Quote Originally Posted by Patrick Dixon View Post
    No idea, that's why I shared it!
    Like I said, it's from a "read me" file I was given.
    Well the second sentence is obviously wrong!
    I'm Neal.
    I’m with Patrick, which parts are meant to be “facts”? I can’t seperate the subjective BS from thesupposedly technical parts...
    Bigman80 Guest
    Quote Originally Posted by NRG View Post
    No idea!
    I've largely ignored digital music but the Raspberry Pi/Allo Boss DAC has opened my eyes to the vast library that can be created, very quickly and enjoyed at the touch of a screen.*
    I just felt this was an interesting read and wondered how much was actually fact Vs fiction.*
    That's why it here, to get the opinion of those who might know!
    Bigman80 Guest
    Probably but that was the title of the file.
