Results 1 to 7 of 7
Thread: QED Genesis Silver Spiral - Interconnect?
    I'm Shane.
    Default QED Genesis Silver Spiral - Interconnect?
    My Dad is using Silver Spiral Speaker Cable. Did QED also produce a matching interconnect?
    S.
    Shane Lonergan.
    I'm Kevin.
    Have a look on google?
    Kevin
    I'm Neil.
    Quote Originally Posted by southall-1998_mk2 View Post
    S.
    Yes they did, not as good as the speaker cable, but a nice evenly balanced cable. I have used both, and still use the speaker cable.
    Regards Neil
    I'm Shane.
    I see they no longer make the silver spiral interconnect anymore. Their most expensive interconnect is the signature audio 40.
    S.
    Shane Lonergan.
    I've got a few I don't use anymore if he's interested in going all Silver Spiral!
    I'm Shane.
    He's settled for a 'less quality' QED cable. Should hopefully suffice. If he decides to upgrade, I'll message you Lawrence.
    S.
    Shane Lonergan.
    No problem, I used to have the Qnect ones when I started out (Superfi special) and these are a considerable upgrade I can say.
