Results 21 to 30 of 42
Thread: renewing yamaha ns 20 speakers
  1. #21
    I'm arsenico.
    Default first test
    i know that a youtube video is not the best way to share a test, but here you are
    IMHO a chet baker piece with drums, piano, bass and trumpet is one of the most difficult tests for speakers, IMHO again they sound great, pristine clear high tones and smooth silky bass
    https://youtu.be/b6Y1WXesKFg
    happy with them, but,....more to come soon :-)
  2. #22
    I'm Edward.
    videos are both totally overexposed, can't see much. Sounds good, but of course limited by the speakers I'm using here and no doubt by the mic you are using.
  3. #23
    I'm arsenico.
    Quote Originally Posted by Edwardlon View Post
    yep, overexposed to focus on sound, house bad and dirty
    i understand the limitations,
    apologies
  4. #24
    I'm Edward.
    Quote Originally Posted by dequincey View Post
    apologies
    No need to apologise. As mentioned I'm fascinated by these speakers and its pretty unique driver arrangement.
  5. #25
    I'm arsenico.
    and things can be improved substantially,...
    here they are,...
  6. #26
    I'm arsenico.
    Default please help and share your thoughts
    so as you can see i bought these tweeters JA 0506
    my plan is to use them as supertweeters with my ns20 speakers
    i will prepare some base material and put the electronic components on it
    i would like to have you opinion on this, please
  7. #27
    I'm arsenico.
    OPINION PLEASE:
    to use them as supertweeters i will need to prepare a couple of things, a high cut pass filter + an L-Pad for attenuation
    the characteristics of the Ns20 could be assimilated to the bass JA5002
    This is the data about JA-5002
    Voice coil 66mm dia alminium edge wound voice coil
    Alnico magnet
    impeadance 8 ohm
    f0 : 35Hz
    efficiensy : 92dB/w/m
    f-range : 35Hz~6kHz
    and on the other hand the tweeter is:
    the performance curve
    as a summary from specs:
    - the bass is 92dB and frec range up to 6000Hz
    - the tweeter is 115 dB and nice response frec range from 5000Hz
    here is my thinking:
    1- I will cut high pass the tweeter from 5000Hz using a second order filter (a capacitor and a coil); there is a doubt here, to cut at 5000Hz or at 8000Hz ??
    2- I will attenuate around half of the sensitivity gap = the difference (115-92= 23) / 2 = 12dB using a L-Pad filter
    3- this will be the setup: (C and L values are for 8000Hz) where it says CrossOver is the NS20 internal one
    your thoughts ?
    THANK YOU
  8. #28
    Can you not plot the natural roll-off of the main tweeter and mirror (reverse) this for the roll-in curve of the supertweeter? Might need a tweak here and there, but it should give a nice result.
  9. #29
    The speakers already have a tweeter so I don't know what gains you are hoping to make by adding another. From the response you show it doesn't extend much higher than 20Khz anyway. Usually you would look to roll in a supertweeter where the existing tweeter gives out. Do you know the upper FR of the existing tweeter? I guess if it is quite low(15Khz) say then it might be worth trying the supertweeter. Otherwise you are just doubling up on what is there already, you'll get cancellation, reinforcement, comb filter effects. All a bit random it seems to me.
  10. #30
    I'm arsenico.
    thank you, seems a possibility, but unfortunately i do not know how to do this
