What's your preference regarding SQ?
Standard PSU
If ipower
Allo low noise PSU
Battery
Anything else?
I'm back to a basic Pi and want to make sure I'm using the best PSU I can.
Standard PSU
If ipower
Allo low noise PSU
Battery
Anything else?
Chord Mojo / Sennheiser HD600
I'm Luke.
I will follow this thread with interest.
I power mine with a cheap wallwart, but I have been tempted to buy an ifi one ever since hearing the improvement that using a cheap battery pack made. A bit illogical perhaps, but I can't be arsed with rigging up a battery plus charger and would prefer a simple plug and play solution.
Also Allo supposedly have an audiophile 5v switching supply in the works, but it seems to have stalled, as no updates in a long while.
I'm Mel.
A cheap and easy way try a battery is to use a power pack designed to recharge smart phones.
I Use a couple of large rugged ones bought from Maplins for fiver when they were closing but mainly to give me a portable option for playing. I also have a dedicated linear unit from Audiophonics as well as the Pi branded wall wart - I can’t hear any difference between any of them.
Haven't tried a battery... however, what I can honestly say is that for me I was sceptical about power until I eventually gave in and paid £49 for the ifi powersupply
https://www.amazon.co.uk/iFi-iPower-.../dp/B01GNNXP0Y
OMG I couldn't believe the difference it made to sound quality, over the "official raspberry pi supply". Personally I consider the ifi an essential purchase - one of the best £ for sound purchases I have ever made
lossless > Raspberry PI-3b+ > allo Boss > Van Damme Purple interconnect >
Myryad Z210 CD Player > Chord Chameleon Silver+ interconnect >
into Magnum IA170 amplifier > Van Damme Blue 4mm cable > Mission 752 Freedom Floorstanders
Headphones: Audio Technica ATH-AD700 Open-back
I'm Adam.
I have one of those too powering my Pi. Previously I had an Anker battery which was OK but too much hassle. I then had a Chinese Linear Power Supply which kept drifting away from the 5v on the LED display (not a sound quality issue but annoyed me)....
....the Ifi is just fit and forget and sounds fine to me!
Adam.
5v 20,000mah imuto battery. works very well with an inline switch
I'm Luke.
I'm Luke.
