![Quote](/images/misc/q.gif)
Originally Posted by
Liffy99
Hi
Crossover is set at 280Hz (48db/oct Linkwitz Riley).
Stats have had upgraded panels fitted with improved coatings (the originals were often prone to failure) and the stators carry the high voltage now, not the membrane.
Made them slightly more efficient and a tiny bit clearer to my ears.
So the stats just don't see much in bass terms, allowing them to play louder in conjunction with the corner woofers.
The system needed considered setting up mind as there is a 10db+ efficiency difference between the two driver technologies.
The room correction software helped a great deal, although I felt it sucked a little too much bottom end away so I have the slave amp's output dialled in at -5db rather than the 10 the correction software would have left.
Itching to listen to the Sanders Sound hybrids though - rare as hens teeth in the UK.
How are the MBLs ???
Never liked what room correction does, prefer room treatment. Nice set up, needs a turntable though
