Originally Posted by
Andre
The plinth with the rounded edges looks very Art Deco..looks cool. Fidelity Research 'FR-64' is a good arm for the '401'
I saw the rounded edge model with vertical layers of plywood and wanted it immediately . My plinth is solid plywood,so it is heavy and stable as I wanted it to be. When talked with Russ, he actually said this model was his first design. If you look his furniture he has used a lot of exposed plywood.
Now I am just waiting my isolation feet to arrive.I bought 4 disks of silence, and they are specified up to 90kg carrying capacity,so should be enough .
My Gear
Source components:
Garrard 401 in a solid birch plywood plinth / Trans-Fi Terminator T3Pro / ESCo modified Denon DL-103
Pioneer TX-9800 tuner
Amplification:
Art Audio Diavolo and Conductor, Pair of XTZ Sub Amp 1's, Nick G 'Dual Phono' phono stage
Loudspeakers:
Bastanis Mandala Atlas with 15" sealed woofers
Cables:
Analysis Plus: Big Silver Oval speaker cables and Silver Oval-in interconnects, Mark Grant DSP 2.5 Dual Screened power cables
Record cleaning
Nitty Gritty 1.5Fi MK II
