I originally designed the SR4 as a low cost option for upgrading the Technics SL1200/SL1210. The SR4 design has also been set up to provide power for other items of equipment with different voltage and current specifications. The SR4-12 has been used with the V DAC providing a nice upgrade in sound quality over the stock power supply. It also works well with the SB3 and SB Touch. I have used it with the Altmann Attraction DAC for the main 12v supply. The SR4 is comfortably beating typical low cost wall warts, both linear and switching, and giving a very good account of itself musically.
The SR4 can be set up for use with any of the following items of equipment :
Squeezebox SB2, SB3, Duet and Touch
M2Tech Hiface, Hiface II and Hiface DAC (with breakout cable)
M2Tech EVO Spdif interface, EVO Clock, EVO DAC, Young DAC, Joplin ADC.
DacMagic, Chord Qute, Caiman DAC, Weiss INT202, Antelope DAC.
There are many more items of equipment that the SR4 can power as long as their power requirements are within the voltage and current range of the power supply. When set up within the output voltage range of 5v to 12v the SR4 can deliver up to 1.8 amps and set up for 15v to 18v it can deliver 1.6 amps and set up for 21v it can deliver 1.4 amps.
All SR4 sales enquiries should be via ACS Ltd.
David Webb can be contacted at :-
Advanced Camera Services Ltd
Unit 10 Linmore Court
Threxton Road Industrial Estate
Watton
Norfolk IP25 6NG
T 01953 889 324
F 01953 880 086
ACS_2005@BTconnect.com
www.advancedcameraservices.co.uk
Opening Times 9.30am–5.30pm Mon–Fri
If we can be of further help let us know.
Regards
Paul and ACS
