Results 1 to 10 of 17
Thread: Speaker cable suggestions.
    I'm Craig.
    Default Speaker cable suggestions.
    I will be in need of a fairly lengthy run of speaker cable, probs about 5 metres on one, and seven on the other, ok not that long a run, but I don't want to spend a lot on it, so fire away!
    Bluesound Node 2i
    Audio Analogue Pucinni SE
    B&W DM607 s2
    Klotz ic’s
    Mains cable 3 core and some plugs?
    I'm Craig.
    Quote Originally Posted by AlanS View Post
    A good suggestion, but not the best looking option as they will be seen a fair bit.
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm Jerry.
    This was recommended to me by an AOS member and I think it's better than most expensive cable:
    http://www.ebay.co.uk/itm/3006092739...84.m1423.l2649
    Now you can't complain about the price can you?
    Jerry
    Hifi: IPL transmission line floorstanding speakers, Squeezebox Touch, Denafrips Ares 11 DAC, DCB1 Pre-amplifier, Croft Series 7 power amp.
    Custom Hifi cables HA10SE headphone amplifier and Hifiman HE-400 headphones.
    AV system: LG 55B7, Denon AVR -x2300w receiver, Quad 12L (front) 11c Centre and 11L rear . Velodyne DD15 subwoofer.
    My usual suspect black rhodium twist at 1.49 a meter. Fantastic stuff that has off cables costing considerable more.
    PRE
    I'm Craig.
    £1.49 ?
    I thought it was about £3.50?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm Mark.
    Are you sure its £1.49, maybe that's your special price
    The twist only has 0.75 mm conductors which is really small for 7 metre runs.
    For 7 metres I would use something 1.5mm to 2.5 mm or maybe 4mm.
    I'm Craig.
    Quote Originally Posted by Mark Grant View Post
    Care to stick brands onto the sizes Mark?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    Merlin CR4, if you can get it. Looks nice in pearlescent white and not too dear. Sounds excellent too. Pretty stiff due to solid cores. Good cable!
    I'm Shane.
    Are they discontinued now?
