Hi to all Garrard 401 users.
I had some spare time on over the weekend and decided to check my Garrard 401 main bearing. All looked great inside and outside and after a good wash with IPA it looked good as new
I just need to order the felt oil pad on the top and the main bearing gasket on the bottom. What would be the best oil to use inside the bearing? Bearing has no slag and is really well looked after by the previous owner. I just want to have the right viscosity oil suitable for the bearing.
And please don't suggest using normal motor oil, because I am not going to use that .
P.S. I wrote to Dom to ask about his TT oil, but haven't got answer back yet.
