Page 1 of 11 123 ... LastLast
Results 1 to 10 of 104
Thread: Garrard 401 | SME 309
    Default Garrard 401 | SME 309
    Its powered up, it has an arm fitted, it has a cartridge on and its spinning nicely, slight ammount of noise which I can live with, sounds majestic, pictures to follow.
    I'm Hugo.
    Did you get the SME spacer from Sound Supports, then?
    I'm ILOB.
    Yes the 401 sounds nice It might be worth looking at the idlier
    What plinth are you using
    Quote Originally Posted by Shuggie View Post
    Yes thanks Hugo, much appreciated good advice from a top bloke, thx again.
    Quote Originally Posted by John View Post
    I needed a quick solution (when I bought it I though I would get it up and running in days, it took 3 months in the end) so I bought an MDF 2 tier plinth which does the job.
    The slate audio new design is £1300 BTW, if I was keeping the 401 and did not have my Techie I would be tempted but no.
    I'm givingyouaprettygoodclue.
    There's a lifetime of modification fun to be had with the 401. For starters if you had a lilac plinth like mine you'd find yourself redecorating your house...
    Pete
    Quote Originally Posted by Pete The Cat View Post
    Pete
    No shit mate. I have the exact same plinth myself...
    In-between the Mike Greenwood design and the full remortgage slate plinth are a number of attractive wooden options eg www.layers-of-beauty.co.uk It occurs to me that the thing to watch out for is the ones that, while looking a million dollars, are hollow boxes like 401's used to suffer from in the 70's.
    Pete
    Pete
    Russ has made me plinths in the past and is a master of his art, don't know what to do yet with the Garrard, may sell it.
    Alex_UK's Avatar
    The funny thing is, I passed on the lilac plinths on ebay several times... then we ended up decorating the living room lilac anyway!
    So, David - I'm guessing you're not enjoying the 401 as much as the Techie? Try it with the Nagaoka before you decide to part with it...
    Alex
