Originally Posted by
bpcairns
Hifidelityguy-
One of Stans own mods involves soldering coupling capacitor onto a point past these relays, no-one has reported a problem, in fact I read somewhere on here that the main purpose of these is to give very good test results for signal to noise in synthetic tests. So it looks good when compared to others.
The noise is the mechanical reed switch turning on then off. A different transport makes no difference. When the sound stops, the DAC "squeaks", "twirp" would serve as well as a description.
I've tried my DAC in another system with both CD and a different PC feeding it (SPDIF) it squeaks every time the music stops, either at the end of tracks or if the music is paused. My friends identical Caiman does not make the noise. (well it does but it is much quieter and can't be heard unless you stick your ear very close to the DAC. ) Incidentally playing a gapless CD like Pink Floyd's The Wall there is no problem, The music never stops so the relay never squeaks. I'm convinced that I have (probably one) particularly noisy component in my particular DAC and any benefit it is supposed to provide is outwieghed by the component being faulty. I could buy a replacement and it MIGHT be quieter but I'm 100% certain a wire link will make no noise at all....
