Results 1 to 10 of 18
Thread: Allison Bass driver repair
    Default Allison Bass driver repair
    I was scared of doing this repair for about 2 years, why I don't know they were knackered any way, what did I have to lose, so I bought the repair kit and this is how I did it.
    this is what they looked like when I started
    I made a cone support from a piece of hose pipe
    then I used thinners to clean the metal basket and very carefully the edge of the cone, I used a craft knife and cotton bud
    next I used a small blade craft knife to cut the central dustcap(scary bit) note the angle of the knife is parallel to the cone to avoid cutting the fine wire beneath.
    I then used thin strips of plastic coated paper as shims to centralise the cone before glueing the new foam to the cone
    after the glue had dried I then glued the foam to the metal basket with a soft brush
    clothes pegs as clamps, taking that the shims centralised the cone I glued the foam to the basket where it lay, I didn't try to centralise that as well.
    I used a piece of blutak to lower the dome exactly where it came from, as the cut was a bit wobbbly it was easy to line up where it came from.
    I used a small file to weigh it down gently whilst the glue dried
    and Voila! the finished Item, once the glue dried they look quite good I thought
    back in the Allison 3 cabinet yahoooooo
    I hope it has been helpful to anyone wanting to have a go, I missed out on 2 years of my favourite speakers now they are back sounding beautiful.
    good luck
    regards Al
    My system,
    Cartridges Lyra Delos, Audio Technica AT33EVmc, AT 24 mm
    Turntable Thorens TD 124 Mk2, in a Jim Campbel plinth,Audio Technica 1503 Mk3 arm
    CD player Technics SL-PG490
    Cassette deck Yamaha KX 530
    Moving Coil Amp Albarry MCA 11
    Pre-amplifier Albarry AP 11 (battery powered)
    Power amps Albarry M1108 Mono-blocs
    Speakers Allison 3 Corner units, Allison 6 stand mounted cubes
    Interconnects AVT Matrix 6 and OFC short ones
    Mains distribution Music Works Recoil 6 gang and mains leads
    Tables MusicWorks ReVo acrylic stand, Quadraspire Acrylic shelves (cryo'd legs) acrylic Response Mini under mains block.
    Speaker cable Chord Rumour (Cryo'd)
    RCM Okki Nokki
    https://www.facebook.com/groups/1586...homepage_panel
    I'm anOrgoneAccumulator.
    Well done Al - pleased you've got them up and running again! Have the mid/tweeter units been repaired at any stage?
    Main System - T/T: Trio L-07D/Benz Glider; SME V/Ortofon Cadenza Blue; Audio Technica AT666EX vacuum disc stabiliser; Audio Technica AT636 Audio Insulator Feet. Phono: Whest PS30R. CDPs: Esoteric UX-1; Micromega Classic Solo. Amps: Exposure MCX Pre/4 x Exposure XVI Mono Power. Speakers: Jamo R909/Townshend Seismic Sink stands/Audiosmile Mk 2 Supertweeters. Headphones: Audio Technica ATH-W1000; G&W TW-J1 head amp.
    Second System - Digital: NVA TFS. Amps: NVA P90 Pre. Speakers: B&O Beolab 6000 Active.
    I'm Keith.
    Nice work Alan.
    Keith
    Analogue: Lenco L75 with 'PTP5' top plate in heavy birch ply plinth/re-wired Rega RB300/SAE 1000e HOMC Cartridge/Trans-Fi Reso-Mat/Moth RCM
    Files: Voyage MPD/Custom PC/Supra USB/Beresford ASYNCH-1/Beresford TOSlink cable
    CDP: Inca Katana SE
    DAC: Beresford Caiman MkII (LiPo Battery powered)
    Pre-Amp: Croft Micro 25 Power-Amp: Croft Series 7
    Speakers: DIY Frugel-Horn Mk3 ('FH3') + REL Strata subwoofer
    Headphones: Beyer Dynamics DT990 Pro (250 ohm)/Schiit Asgard Headphone Amp
    Cables - Interconnects: Mark Grant G1000HD Speaker Cables: Van Damme Blue
    Mains: Belkin PF30/Mark Grant DSP2.5 & DSP1.0 Rack: Target
    Office System: HP Win8 Laptop/JRiver/MF V-Link2/Beresford Bushmaster MkII/Topping TP20 Mk2/Mission 771e
    Bedroom System: Raspberry Pi/Raspbrian + MPD/HiFiBerry DAC/Topping TP20 Mk2/Mission 760i or DIY Hybrid Valve-MOSFET Headphone amp + Sennheiser HD595
    Gallery
    I'm fuckoff.
    Does using glue change the sound of it? As it was never there in the centre to begin with, I'm guessing yes?
    Quote Originally Posted by realysm42 View Post
    I doubt it very much indeed. PVA is pretty elastic so it'll just aid in damping the thing, the only difference may well be in a very slight alteration of the driver parameters due to a very slight increase in mass.
    It'd take some serious measuring gear to find that difference though
    So I reckon they'll sound as good as new
    Bests, Mark
    I'm NotAnAudiophile.
    Fantastic little tutorial, thanks very much for sharing Alan - they look great
    Some people have no idea what they're doing and a lot of them are really good at it.
    George Carlin
    Boycott the US
    I agree with Mr Malenfant, the centre cap is just a dust cover, I laid the glue over the cut line in order not to leave any air holes, as the glue is reasonably pliant when dry and there is only a small amount of it, I don't think it has made any difference, whilst it's hard to remember exactly what they were like when I bought them in the 80s they certainly sound fantastic now and I'm glad I took the plunge.
    regards Al
    My system,
    RCM Okki Nokki
    Quote Originally Posted by Theo View Post
    Hello Theo,
    The only thing that seems to go wrong with Allisons are the bass foam surrounds.the tweeters and mid range seem fine, I love the large sound stage Allisons give, and although the 3s are 4ft tall they get lost standing in corners.
    recently I was lucky enough to try the new Albarry M1108 Mono-bloc power amps through my 3s, what a beautiful control and delivery, I can't wait to afford a pair.
    I hope you are enjoying your LO7D, what a deck eh!
    regards Al
    My system,
    RCM Okki Nokki
    I'm Deleted.
    Strangely enough, I have a pair of Alison Six speakers that need re-foaming; have just ordered the roll-surrounds now .
    Account Deleted
    Alex_UK's Avatar
    Top Job Alan (and good luck Mark!)
    Alex
