Results 1 to 10 of 15
Thread: best home sound for 800 euros?
    Default best home sound for 800 euros?
    Hello,
    I have just received a voucher for a hi-fi system (800 euros). What would you buy? (Large living room, all kinds of music, detailed warm sound...).
    Thank you so much.
    david from Brussels
    I'm BigBobJoylove.
    Hi David and welcome!
    A voucher eh? Interesting, where are you able to redeem it?
    For 800 euros you may be best going for used components as you'll obtain much better quality per euro. What source components do you need?
    Lounge:
    Samsung QE65QN80F 65" QLED TV
    Echo Link streamer
    XMOS DSD Async
    Emotiva A2+ power amplifier
    Neat Motive SX1 speakers
    Van Damme 4.00mm tour grade speaker cable
    Audiocrast Spreizbar banana plugs
    Studio:
    SMSL SU-1 DAC
    Modified Fosi P4 preamp
    Adam Audio T5Vs
    Fenton 10" active sub
    Fosi V1.0G integrated amp
    Roxel RBS 300s
    Several small valve preamps
    I'm notAlone.
    Easy:
    First you choose a pair of speakers that you like, for about £450-500, then you add
    Source: Sony SCD-XE597 (£150)
    Amplifier : Nuforce Icon (£200)
    (all new)
    Dimitri.
    George Orwell
    I'm Peter.
    Or,
    Pioneer PD S703 (one on Ebay currently for £75 - which is a bit pricey).
    Behringer power amp (referred to in another thread recently, at £170ish new)
    A Croft Micro Basic 25 (£350 new)
    And some speakers with the remaining money.
    Or you could probably pick up a Quad 33, 303 set up for the same amount, or less, as the Behringer and Croft.
    Peter
    What's this beringer power amp?
    I'm Peter.
    Behringer A500
    I'll try and find the recent thread where it was mentioned and praised.
    Peter
    Cheers!
    Alex_UK's Avatar
    Staying with the Behringer A500 theme:
    Pioneer DV-575-A Multidisc player (Ebay, 2nd hand) - £30
    Beresford Caiman DAC/Pre-Amp - £230
    Behringer A500 Power Amp - £170
    Wharfedale Diamond 10.1 Speakers - £200
    Ebay Speaker Stands to suit - £50
    Mark Grant Cables - £50
    Total cost: £730
    No idea if it would work together, but I really like the idea of feeding a power amp direct from the Caiman, and if you're using a DAC the source just needs to be a decent transport.
    Alex
    Alex_UK's Avatar
    Quote Originally Posted by symon View Post
    Behringer A500
    Start here - then view the remainder of the thread:
    http://theartofsound.net/forum/showp...3&postcount=97
    Alex
    I'm Peter.
    http://theartofsound.net/forum/showthread.php?t=4526
    See Jerry's post about half way down, with pics!
    Peter
Tags for this Thread
