Originally Posted by
walpurgis
It shouldn't make any difference whether you connect to LF or HF as long as the jumpers are firmly fixed and polarity is correct.
Yep. Quite impossible for it to make a difference. However, if the connections were not tight and or were a bit corroded or dirty then the action of making the fresh tight connections would give you the results you found
