Quad 22 preamp.
The picture above is in it restored state.
I was give this preamp last year and as part of my scrapyard refurbish, I decided to see what it would take to get it to work in a modern set-up
First thing first it needed a power supply and after rummaging around I found all the bits.
Well first thoughts listening to it using the standard inputs, it had a soft warm sound with a lack of bass when plugged into my Linn Intek.
Years ago when I used to use the Quad 22 I use to feed line level equipment into the tape output with all the input buttons switched out,
this feeds the signal into the volume control removes the veil sound from it by bypassing the EF86's.
When connected to my Intek and using the Quad 22 tape output as the input the sound open up but it still had a lack of bass.
The big problem is matching the Quad 22 output with any thing less than 1M ohm input impedance as the ECC83 has a very high anode impedance.
More to come....
Quad 22 preamp revived...
Modification...
Mods please feel free to move it Past Master if needed.
Sharif.
