Now that I'm the proud owner of a Dr Feikert protractor, thought I'd ask the question, what geometry do folk use for set up, and why?
Hunter S Thompson
I'm Andr'e.
It's like heaven when you use a TT that needs absolutely no geometry set up, no cartridge alighnment. just tracking force.
Which TT is that mate?
Hunter S Thompson
I'm gordan.
probably a laser one
Gordan.
Speakers: Oris Swing MkII
Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
Preamp: Silver AVC by eng. Ferenc Lazar
Phono Preamp: Shishido LCR by Solaja Audio
Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
Wires: of sufficient length
perhaps, like the Universe, it begins with a 'Bang' ....
I'm Andr'e.
That's what Ortofon say about their tonearm geometry
http://www.ortofon.com/products/tonearms/ta-110
Chris
Common sense isn't anymore!
I have and use an inexpensive Ortofon alignment protractor and set up my cartridges using that.
If I have a paranoia attack I can always check with the alignment disc that comes with the Hi-Fi News test disc - it's the same alignment.
Chris
After, like, ten posts you will have at least one answer..
I use the Baerwald alignment on my Dr Feickert NG protractor, which by the way is an absolutely amazing tool!
I use Bearwald as i belive its the one that gives the lowest average angular fault over a standard LP side?
Do you have another favorite?
Best regards Mike
