Opinions and/or questions would be most appreciated.
I have owned an LP12 for a little under a year now. It has a Cetech subchasis, Hercules/MOSE power supply and an Origin Live fully modded RB300 with AT440Mla cartridge.
It took an age to set up properly as the OL RB300 causes untold problems with its cable but set up it is and unlike ordinary RB300`s these do play on LP12`s especially with a Cetech subchasis.
It sounds fantastic - depth & breadth of sound staging superb; high, mid and bass tones are wonderful and balanced, timing and seperation excellent, etc etc. (bearing in mind I came from a fairly mediocre starting point.)
I have recently finished restoring a MK1 TT2 and fitted an unmodded RB300 with AT110e and run it through the same system. A lovely piece of turntable kit in itself.
Today out of interest I have run a side-by-side A/B comparison and found that there is literally a hairs breadth of difference between the 2. The TT2 set up has a slightly `boomier` bass, a little less seperation and the timing is not quite so precise.
However I know from running A/B comparisons of both the carts and arms that these differences are predominantly down to these 2 factors and that if I swap the OL RB300 & AT440MLa over to the TT2 I`m sure most of the differences would disappear.
My questions are:
Has anyone else ever run an A/B comparison of these 2?
Or even owned them in the past and found the same as me?
Does anyone with a good knowledge of these 2 have an opinion about these 2 TT`s, eg ex-dealers, people used to set up and servicing of both?
Is there something glaringly obvious or subtle I`m missing with either the LP12 or the Heybrook TT2?
Is this a case of the `emperors new clothes` and actually the LP12 with or without all it`s mods is simply not as wonderful as it`s reputation deserves?
By the way I have also posted this in VE so I can hopefully get broad opinion base.
Cheers in advance.
