Page 359 of 375 FirstFirst ... 259309349357358359360361369 ... LastLast
Results 3,581 to 3,590 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #3581
    Alex_UK's Avatar
    Thanks Grant, that's good to know. I'm thinking of going wireless for Teams calls, but usually only me in the room so NC not really an issue. Food for thought...
    (My boss has some strange looking ones with much larger discs on top - looks like he has mushrooms in his ears! Has earned him the nickname "Uhura"!)
    Alex
  2. #3582
    Quote Originally Posted by Alex_UK View Post
    fit well these and unobtrusive. total time usage is 45 hrs using case to recharge the buds, tho between charges you get a decent time, as no noise reduction (anc) uses lot of battery. audio on a call was really excellent on both ends. music sound good too.
    Alex_UK's Avatar
    Thanks, added to my shortlist! (Just got a new work laptop, and will make sure the Bluetooth works okay with daughter’s cheapies before committing to anything, that can wait until New Year!)
    Alex
  4. #3584
    ordered a new tv
    LED HDR 4K Ultra HD Smart TV, 43 inch with Freeview Play. got a good price on it and its a little bigger than my 37 incher.
    dunno when itll get fitted mind, as i will have to wait on someone to fit it. not sure if i will wall fit it or just as ive got current one, on a wall shelf.
    I think many folk mount them too high up on the wall, and doesn't make for relaxing viewing, especially if you're sat quite close to it. If you have it sited where your current one is, it might seem a little higher up anyway, with it being bigger.
  6. #3586
    i agree. mine is centre of tv at eye height when im sitting. im maybe 8 ft away. as one i have has a fairly big frame, this new one wont be physically much taller(inch or so) but a little wider. The wall bracket has a couple of glass shelfs. They are not especially stable but as long as it fits(central stand as opposed to feet), i doubt it will be much heavier so should be ok.. If not or im dubious i will just get an adjustable vesa one.
    43 is quite a bit bigger than 37, you'll be able to see what's going on in the films now
    If you don't have a big telly then you're missing out on the only positive thing about living in the future.
  8. #3588
    I didn't want that to be true, but I really can't think of anything else.
  9. #3589
    We have both a 37" and a 43" telly and find either acceptable in their respective environments. The 37" sits higher than the 43" - and I have to say I prefer watching the 43"; not because of its size but because of the viewing height relative to the sofa. The viewing distance to either screen is similar (~ 2m).
    Alex_UK's Avatar
    The previous owner of our house mounted the TV on the wall above the fireplace, in my opinion it was much too high, but luckily I was able to hide all the cabling behind a box canvas picture that fits perfectly and the TV is in a much better position in a cabinet.
    Your new one looks good, Grant. Enjoy!
    Alex
