Does anyone use j river jukbox 14, only im having problems with album art, its
finding some but not all, it appears to be getting it from its database, and not
selecting to use the j peg with flac file.
thanks phil.
I'm Phil.
thanks phil.
Phil.
I used to use it before i bought J River Media Center, but i had none of the issues you describe? Are you sure that album art IS correctly embedded in the files? (That is, checked them using iTunes or Media Player)
Regards //Mike
