Hi there SB users...
I have four SB clients/players in the house, all being fed from a QNAP TS-119Turbo server, running LMS 7.7.2, and a FLAC catalogue.
Until recently both my downstairs players were SB Receivers (Kitchen & Living Room). I often like to synchronise these players, it makes cooking a more enjoyable experience...
Recently I upgraded to a SB Touch on my main/Living Room system, and since then whenever I run it in a synchronised mode with the Kitchen, every now and then (5 to 10 mins between but not predictable) I get an audible 'click' from the Touch, but no such issue from the receiver.
This 'click' is not there when I run the Touch on its own.
I've gone from coax to USB (EDO) on the touch, and have added a USB galvanic isolator, however the above behaviour is consistent. I've messed around with the buffer settings in EDO, but the issue is still there...an occasional 'click' from the Touch when synchronised to the receiver, perfect on its own.
All SB players are at the latest firmware level, and the Touch is now at the latest EDO, but the click has always been there regardless of the Touch's firmware. I've also monitored the M-DAC's USB buffer level when the 'click' occurs, but it's steady at 50%, so the 'dropout' or whatever it is, isn't happening there.
FYI I've only just realised that the click only occurs when I synchronise the Touch with the receiver...which comes as something of a relief, I thought there was something wrong with the Touch at first
Anyone had any similar experiences when synchronising different SB players?
P.S. Monitoring of the server reveals that it isn't a server CPU issue, it runs at about 15% even if I synchronise all four of my clients, or have them playing individually in parallel
