Here are a few pictures of the of my rebuilt 1959 Stereoscope 555 integrated valve amplifier.
I've also found out they were made by Clarke and Smith famous for making the Ferrograph equipment.
I've owned it for over 20 years and I paid about £60 for it so I've no idea what it worth now?
I rebuilt it about 10 or 12 years ago as most of the components had suffered due to the heat.
All the resistors were replaced in main areas with 2 watt high-stab carbon film and the ceramic capacitors were replaced with polypropylene ones.
As for it sound quality it very good having comparing it to the small valve TL12's and the Stereo 20 it had a similar sound but it just sounded more neutral.
Side view of preamp.
Front view.
Left hand underside of preamp.
Right hand underside of preamp.
Underside of poweramp.
These old integrated amp are now extremely rare as most of them have overheated in such a small case, this one was in a very bad state when I bought it.
They are well worth restoring if you fancy a challenge!
Does anybody know any more about these amps?
Most of the info I found on the net talks about it being a monitor amp for use in studios?
Sharif.
