Pig ugly too!
Pig ugly too!
I'm Clark.
Agreed, more function over form, but then wall mount supports don't win any prizes for asthetics either. Bit smaller though.
Turntables like wall shelves. You would think otherwise but they do. Even a stud wall seems to work ok. Even lightweight DIY shelves seem to sound quite nice.
I've tried a lot of tables and supports and the best I've used by a country mile is Mana. It's stunning and well worth the cost. Even then a Mana wall shelf is better than a floor stand, even John Watson of Mana said that. But if the floor is sturdy and the wall wobbly I'd go for a floor stand.
Hasnt Manna folded?
The wall i was going to use sounds like a snare drum when you tap it, its been built using two stud skins so in effect its a big empty chamber.
Oh yes, long time ago, but you can still find the stuff on the used market. It'll be around for a long time, it's virtually indestructible!
How that would sound who knows. It sounds like a bad idea but so does a lot of things that work ok. What you can do is rip the wall open, add strength to the inside then re-sheet it. You can put in wooden straps exactly where you want to hang the shelf.The wall I was going to use sounds like a snare drum when you tap it, in effect its a big empty chamber.
Not a bad idea. Could even fill the cavity with sand.
Colin, what i suggest you do is find out where the studs are & get a couple of bits of 3/4" MDF & glue them together (or use one piece of 1" MDF) & make a board big enough to attach the wall mount to the studs directly...
It shouldn't be too difficult & at the end of the day if you remove it you'll just have between 4 & however many screws holes you choose to fill in
Bests, Mark
That sounds easy do able
