Results 1 to 10 of 11
Thread: Universal remote
    I'm invisible.
    Default Universal remote
    Any suggestions. Mainly for use with DVD and TV.
    If only it was that simple
    Main System :
    Quad II/40 amps, Music First passive pre, Tannoy Stirling SE speakers, Technics 1200 + RB301, V-LPS, digital streaming from Mac mini via Lifatec Toslink to Moon 300D. Meier Corda Arietta headphone amp, Sennheiser HD650 Phones. Mark Grant i/c cables. Speaker cables, Audioquest Rocket 44 BiWire.
    Ray.
    Alex_UK's Avatar
    How much do you want to spend Ray? Logitech Harmony range are always highly regarded, but I went for a Philips Prestigo SRU8015 'cos it looked a bit nicer and has a (teeny) colour screen - £69 on Amazon - some mixed user reviews on there but I'm happy with it.
    Alex
    I'm invisible.
    I'll go to 100. Had a look at the logitech ones and they look very good. But, as always, the ones I liked are wayyyyy too expensive... So I'll have to tone down a little.
    Main System :
    Ray.
    How about a 6 year old child, you just tell um what to turn on / up and they do it plus they're a leaning remote, so the longer you have em the better they get, mine can even make a half decent cuppa now
    Got one from the poundshop,works my cd94 fine,also pioneer cd player.
    Dave.
    Don't need any Tannoys - I've got the best. All cables supplied by pound shop or better.
    Cheatfinder General.
    I'm Bernie.
    I have a Logitech Harmony 555 and it is brilliant. Replaced half a dozen remotes with one and is very easy to program. Most hardware profiles are already available online for loading and configuration. I couldn't live without it now. Best bit of kit I have bought in a long time.
    Bernie.
    I'm Doug.
    Occasionally, if you are very lucky, you can get Harmony remotes very cheaply. If you only need no more than 4 item control, look out for the 300, one of which I bought on Play.com for a tenner. At that price, it is a good option and sturdily built, better than many supplied by manufacturer controllers.
    I'm Greg.
    +1 for the logitech300. AU $10 (7pounds??) at ALDI supermarket last week. Never had one before, plugged it into the Mac, accessed the website, input the brands for the bluray, tv and pvr and i now have just about all the functions i use available on one remote. Wasn't optimistic about it initially but thought I couldn't pass it up for 10 dollars. It really is simple to use
    Greg.
    Thats AU dollars as well, even better value
    Bests, Mark
    I'm john.
