Here's some not so great pics of my rather humble system which is always (and always will be) work in progress.
I'm using Martin Logan Aeon-i's which are a bit close to the walls so I have a couple of homemade absorption panels behind them (bargin, less than £40 to make and really clean things up). This is an older pic so they're not in it.
All the separates are in a hand made cabinet purchased from a local guy. Its a bit resonant but I plan to line it with 3/4" Mdf to dampen it and sturdy it up a bit soon.
The Power Amp is a World Designs WD88, I bought this after hearing quite a few times over the space of a year or so and liking it every time. I put a Maple panel on it after I removed the volume and input selector. I never used these and they developed a problem with a bad earth connection so I just took them out.
The Digital Source is a CD94 as transport with the DA chip and analogue circuits removed. Its a good player but overshadowed nowadays and electronically the power supply rails were noisy due to poor design in this area. Removing all but what is needed for transport duties really cleaned things up. The DAC is a Chord DAC64, not to everyones taste but I like the way it made the speakers acoustically disappear. It also sounded much more serious than the modified Sonifex DAC it replaced.
On top of the unit I have my Garrard 401, again not to everyones taste but set up well there is no idler wheel rumble at all and the sound is a sturdy as a rock. The arm is a modified Rega RB250 and the cartridge is a Ortofon Rohmann which must have the greatest lack of record noise I have ever heard (not heard) from a cartridge.
The Phono Stage is a Pro-ject Tube Box which might seem a bit lowly but I find it very seductive, especially with vocals.
The Pre Amp is a World Designs Pre3. I took my then current home made pre amp to WD for a shoot out. My offering was by no means a stinkers and had seen off many other amps but it was completely shoot down without a parachute.
Well thats about it.
