Ok Anthony, yes i do agree that transformer isolation is a good thing But an output capacitor will give the same protection in reality.. Not that i'll be using one
These will be over engineed. I have 4.5KW (dissipation) of transistors for each class B amp & 1.8KW on each class A section. They'll run at a cool temperature under normal conditions, i figure the heatsinks will be about 10C above ambient with a 4 ohm load & 11 Amp quiescent. Only 5.5 Amp for 250W 8 ohm allowing for a 6 ohm load..When driven though this will increase obviously, but this is a huge amount of heatsinking even for a 500W RMS class B amp. So going to H class with the rail switching will definately keep things cool
There will of course be some kind of protection for the loudspeaker if things go wrong
