With limitations and £5.99
http://www.apptism.com/apps/flac-player
good shout!
why did I buy only an 8gb model?
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Woo Hoo! Thanks for the tip Hamish. No more needless transcoding!
Nice one !!
Bugger...I've got it loaded on my ipod touch, but my itunes screen doesn't look like the example they give...and I don't know how to load FLAC files onto the Flacplayer.
As far as I could tell you click on your device in iTunes, go to the Apps menu and scroll down to where it's got the list of applications that have file sharing enabled. Click on Flac Player, and you get a box to the right which has an 'Add' button at the bottom of it, which brings up a window where you can navigate to the folder / files you want to load up.
Somethng like that anyway, I did it without looking at the instructions because I figured it would work like AirSharing. Anyway, it loaded my files up happily enough and it works great! Top banana!
Can't seem to get beyond this...
How does it sound nick...
I have been to busy to play with it yet...
I have been waiting for fla support for so long now, I check the app store most weeks and have followed (lightly) some people progress, I think there is another company who has something similar in the pipe line too... Although I can't find info now...(?)
(very pleased he bought a 32gb model)
EEJIT !!!
