Has anybody got one?
What is it like? I am still on the hunt for something more flexible than my Topping Pre90. This looks like it will do everything I want and more.
It will be driving a Modulus 686.
Kevin
A popular choice then?
Kevin
I don't know it but it looks okay. What does it do that the Topping doesn't?
TEAC VRDS 701T > Sony TAE1000ESD > Krell KSA50S > Troels Gravesen Faital 3WC-15.
Musical Fidelity have long been known for the fit, finish and performance beyond their price points, and I've no doubt their M6S Pre will be no different. If I had the money I'd be tempted away from my A5 integrated by the M6S Pre/PRX (maybe one day). Though of course you have the power side covered and then some with the 686.
I think you can buy with confidence Kevin, if it doesn't suit you should move it on easily enough.
Echo Dot, Arcam A75 integrated, Celestion 5's, BK XLS-200 DF
LG 55" OLED, Panasonic Blu Ray, Sony a/v amp, MA Radius speakers,
Have you seen that ATC Floyddroid has just advertised in Private Exhibitions? That might be worth a look.
The M6s is local, as in France.
Kevin
Temptation is back. It disappeared over Christmas, but has reappeared yesterday.
I know it won’t give me much over the Pre90.
I think I am going to have to be sensible, and ignore it.
Kevin
It does get hard once you're up against the end stops but still want to acquire more audio equipment
