I'm Pete.
Definitely a couple of new cable ties required ;-)
With the drive unit removed you should be able to take the top off the unit and will spot the laser mechanism straight away.
The bit to try cleaning is the threaded shaft that moves the laser head, the grease hardens in the grooves of the thread.
If that does not work you will need a new drive unit.
Have fun :-)
Use Isopropyl alcohol to clean the hardened grease off with a small artists paintbrush or similar. Wait till dry an hour or so and use some silicone grease before reassembling. Some use White Lithium grease but some say that as this is petroleum based it can caasue problems with plastic parts.
https://youtu.be/ZCBe7-6rw4M
Sorry Mile, I missed your post, but see that Pete came to the rescue.
Take your time getting to the laser mechanism, if the grease on the shaft looks slightly hardened then clean it off with isopropyl alcohol as Rob said until all removed. Do not force the laser gear mechanism trying to free them, or damage is likely, once clean apply the grease, you do not need loads, there are several youtube videos showing this being done.
I hope it works, if not just replace the CD laser mech. for £40.
If you have not found it already this is the grease https://www.ebay.co.uk/itm/404248339...Bk9SR_LWnpCCZA
Grease is the word. Is the word that you heard. It's got groove, it's got feeling.
Alex
Amplifier: Rega Brio R. Speakers: Spendor SP1. Cables: Various, mainly Mark Grant. Please see "about me" for the rest of my cr@p! Gallery
There was some grease on the rails, not exactly hard, but not soft either. Will clean when the products arrive.
Oh well that didn't work,what next?
