Results 1 to 10 of 10
Thread: Sony TAE-1000ESD - Review
    Default Sony TAE-1000ESD - Review
    If you’re under the age of around forty, and you’re reading this, then the year 1989 probably seems like ancient history to you. But, for the rest of us, it’s like it was only a couple of months back.
    Let’s get our heads together though - it was thirty-five years ago.
    Mobile phones were like bricks, the Soviet Union still existed, and nobody normal had ever even heard of Microsoft.
    The world has moved on of course and, although we have slipped back in a few ways since then (for example we still had supersonic passenger air travel back in ‘89 and we don't anymore), as far as hi-fi goes we’ve advanced some distance.
    Haven’t we?
    Well, if you asked me that a few months back I’d probably have said, ‘Yes. Yes we have.’ But then I stumble across this Sony digital pre-amp that came out in the same year that the Berlin Wall came down, and I have to think again.
    Whilst the UK Hi-Fi scene had a lot of problems in the 1980s, the Japanese were surging ahead, and they were able to turn out some very serious equipment that in many cases has still not been surpassed. And thanks to the under-valued Yen, it wasn’t even that expensive. This pre-amp under review cost around £1000 in 1990. About £2.5K today.
    So what makes it so great?
    Feature-wise you’ve got everything - except the kitchen sink and an MC phono stage. (It does have an MM stage which I haven’t tested).
    There is an 18 bit analogue to digital convertor inside, so all analogue sources connected have their signal digitised. There is no option to bypass, so this is not a pre-amp for the analogue purist. However, they could look for the successor unit to this one, the TAE-2000ESD, which does have a bypass feature.
    Otherwise, if the Technics SL1200 is the Toyota Hilux of turntables, then this Sony is the Nissan Skyline of pre-amplification:
    There are pre-set surround sound settings for concert hall, club, arena etc. These are available for use if you are using the pre-amp in a multi-channel loudspeaker set up, and they are the exact same deal as you get on any A/V receiver.
    I don’t think anyone ever seriously uses these things - do they? Still, if you want this then you’ve got it.
    There is a fully adjustable and variable dynamic range expander and compressor. Essentially a ‘loudness’ control that works both ways.
    A clipping indicator which lights if either the digital input or the output are clipped (there is both digital and analogue variable attenuators to fix this issue if it happens), and there are three bands of digital parametric EQ.
    The last feature is really the party piece of this pre-amp. Nowadays, you can do parametric digital EQ in software like Roon; and some all in one streamer-DACs and some stand-alone DACs offer this feature too. But back in ‘89 it was new to domestic equipment.
    Essentially, it does the same job as an analogue equaliser, but since it is working digitally no noise or distortion is added, and far more accurate adjustments can be made to the frequency response.
    You set a centre frequency in the area you want to cut or boost, select the amount of cut or boost in 0.1dB steps, and select how broad a frequency band you want to affect either side of your centre frequency by setting the Q factor. A little space-invaders style graph on the display shows the slope of the adjusted FR.
    The most useful application for this is in the low frequencies. Got a big room mode centred on, say, 100Hz? No problem. You can just dial out that boom without wrecking anything else. Unless you have more than three bass peaks, you can get rid of all of them this way. And you can save up to ten different settings – if you want to.
    So, why would you get this vintage unit when you can get a modern one that does all this?
    Well, it’s the little things that you won’t get on almost any modern device (okay maybe on an Accuphase).
    The (metal) motorized volume control that still physically turns even when you use the remote volume.
    The little green LED embedded into the motorized volume control that lights up when you switch out of stand-by mode, to show you the volume level.
    (Now in the UK we just painted a white stripe on the pot and, yes, that did the job. But that wasn’t good enough for your 1980s Japanese. They went the extra mile).
    There are no nasty modern blue LEDS designed to burn out your retinas in low lighting conditions. This unit uses a mix of just green and red LEDS, and an orange text/graph display.
    It has proper ‘Japanese feet’, not those crappy looking rubber studs.
    The remote control is massive, with more buttons than Cadbury’s. And it’s programmable.
    The flap along the base of the fascia that hides yet more controls is made of metal, not plastic.
    Okay, whatever.
    But the other thing is the sound quality:
    I know what you’re thinking –
    ‘It’s 1980s digital.’
    ‘It’s got all those bells and whistles - that must have subtracted from the budget for the sound.’
    ‘It’s a Sony, and they’re a mid-fi, mass-market brand that never did anything that was properly good.’
    Well, you’re wrong, wrong, wrong. At least, in my experience. This is quite the best pre-amp I’ve ever had here.
    Perhaps, for some obscure technical reason, it is just a really good match for the Krell power amp I am using? I don’t know.
    But really, it has everything. Clarity that is shocking at times. Sumptuous instrumental timbre. Deep, tight bass. Yes, the sort of bass with the texture.
    Don’t get me wrong, I’m really surprised myself. I bought it thinking that I would have a play about with it for a while, and then relegate it to the TV system. Not a chance now!
    Initially I was a bit disappointed that it sounded a little thin, but just slightly reducing the digital output attenuation from the default setting fixed that.
    With the parametric EQ, I have, after extensive experimentation, settled for only a small cut over the narrowest band centred on 1Khz. (My room is quite large, the speakers don’t go that low, so I don’t have any bass boom in my room).
    Crossover point from mid to tweeter is at 1.5K on the speakers I use. Not sure what exactly is happening with this, but the improvement was something special. A bit of midrange ‘clatter’ disappeared and additional tonality was revealed.
    (That’s not very clear, I know, but how to describe it? - ‘It sounded quite a bit better’ will have to do).
    Maybe it’s just at the point where the midrange driver is starting to go ‘off’ as it rolls out? Or maybe I just have a peak in my hearing around there? I don’t know. Whatever, it works for me.
    Yes, as well as the ADC, inside this unit is a DAC from 1989. Even though it is an 18 bit DAC, it’s probably still some distance in specs from the almost technically perfect DACs you can get today for not much money. Happily I don’t perceive any substantial differences in DACs, even the ones that cost 5 figures, so this doesn’t really matter to me, but your mileage may vary.
    So to sum up - Superb looking and sounding pre-amp. Great build quality. Almost every feature under the sun – and it can be had pretty cheap, even for a good one (about £350).
    If you’re needing a pre-amp and are tempted to get something from Hi-Fi’s golden age into your system, then it’s well worth a punt.
    TAE1000ESD:
    On The Vintage Knob: http://www.thevintageknob.org/sony-TA-E1000ESD.html
    On Hi-Fi Review: https://www.hifi-review.com/153713-s...-e1000esd.html
    On Youtube:
    (Note: As any Sony ES fan kno, the UK models don't have the wooden end cheeks).
    Who is Sergio?
    Who is Sergio?
    I don't know. Just some bloke doing videos on Youtube?
    Maybe it's Sergio Tacchini, the greatest sportswear designer ever? Probably not him though.
    Alex_UK's Avatar
    Great write up Martin, I now think I need one of these in my life but after your review the prices will probably go skywards!
    Alex
    Quote Originally Posted by Alex_UK View Post
    Nah, most people are always after the latest and greatest. I predict that these will stay under the radar.
    ' This is quite the best pre-amp I’ve ever had here.'
    Wow it must be good, excellent find Martin!
    I brought it along to the last NEBO but I think you showed up after it had already had its turn.
    But yes, in my system at least, it's stunning.
    Those were the days when Sony made great products. I bet that would cost £3000-5000 nowadays?
    Strictly by inflation calculator it would be £2.5K - but for various reasons I doubt it would be so inexpensive if made in Japan today. Five grand would be my guess.
    I'm Gary.
    Great write up as always Martin, I enjoyed that.
    Crazy good bit of gear, enjoy!
Tags for this Thread
