Results 11 to 20 of 21
Thread: wtd: a decent cd player under £500
    I'm Phil.
    marantz 6007 is under your budget and a lovely bit of kit . feels far more expensive . cd60 good as well
    Eric Bibb
    I'm malcolm.
    Quote Originally Posted by hifinutt View Post
    I have a Rotel CD11 Tribute but if I was buying now the Marantz 6007 would be my choice
    Audiophile Tosher
    Quote Originally Posted by willbewill View Post
    I have the previous model Marantz 6006 UK edition. Pretty good for the money, though the loading tray is a temperamental shitbag. Maybe the 6007 is better in this regard.
    I'm Phil.
    yes 6007 beautiful , its also easier to get the disc off the tray than the rotel
    Eric Bibb
    I'm Alex.
    I use an Arcam CD73 which I picked up for around £100 and it sounds absolutely brilliant.
    Quote Originally Posted by alcarmichael View Post
    How much better can a player costing thousands sound than one selling for a few hundred. I'm betting there's not much in it, and the extra money is going on better (hopefully) build quality and operation. And appearance.
    you'd hope better ability to read damaged discs without drop out or glitches too but not necessarily the case.
    As with any component there's expensive rubbish out there.
    Not all players have a flat response - shelve the bass up or the treble down a little - warm sounding player
    Shelve the bass down or the top up - bright sounding (aka 'detailed') player. But that is rare.
    Some players have constant mechanical noise. Some have bad internal lay-out and have power supply noise bleeding into the signal - that might be audible as a loss of detail and a mushy sound.
    But those exceptions aside there's not much if any difference, that's the advantage of digital audio.
    I'm Phil.
    recently bought a primare cd 35 after months of deliberation . its reasonably priced , runs 100% silent , smooth operation of tray , quality remote and sounds organic, smooth and has a lovely sound .
    Eric Bibb
    Good kit, Primare.
    Not bad looking either.
    Yeah, I like Primare kit, I like the symmetry
    How about this one:
    https://www.ebay.co.uk/itm/256121892...Bk9SR7yTqKfOYw
    There's another one in silver for quite a bit less, and also a CD21 where the bid is only about £100 with a couple of days to go. Might be worth a punt
