Results 1 to 10 of 13
Thread: What "high end" arm is this?
    I'm Kevin.
    Default What "high end" arm is this?
    I was browsing the interweb while I am in a boring meeting, and spotted this TD125 that looks interesting: https://www.leboncoin.fr/photo_audio...2376995271.htm
    Is the arm anything special, or just a standard Thorens arm?
    Kevin
    I'm Shane.
    Acos Lustre. Decent early 70s Japanese.
    https://www.vinylengine.com/tonearm_...l=Lustre+GST+1
    Time flies like an arrow.
    Fruit flies like a banana.
    I'm Kevin.
    Thanks for the quick response.
    That makes the TD125 look like an interesting proposition.
    Kevin
    That is not the original headshell (which was nothing special). The Lustre arm originally came with a screw in rear armtube extension stub and additional smaller counterweight for use with heavier cartridges. Handy if using particularly heavy cartridges, but most wouldn't need it.
    I'm Kevin.
    Thanks.
    €550 looks like a good deal for a TD125 with a decent arm.
    Kevin
    Thanks.
    I think it's a fair prospect.
    I'm Kevin.
    This idea has been binned. The washing machine decided to stop spinning yesterday.
    It could just need new brushes, or it could be something more serious. Troubleshooting will commence shortly.
    Kevin
    I assume you will have checked the filter that there's no blockage, machine might not spin if it's still full of water. This suggestion comes from a position of zero technical knowledge and a rather patchy memory of a similar problem.
    I'm Kevin.
    I have thanks. That is the first thing I did.
    It needs new brushes. I have got it working for now, and the new brushes arrive on Tuesday.
    Kevin
    Cheap fix, does that mean the vintage turntable impulse buy is back on then?
