What are you using on your Turntable bearing to grease/lube or oil it.
I know this question has come up before but I though it might capture what folk are using currently.
depends on the bearings tbh..
Audio Origami bearing oil, which I think could possibly be “Slick 50”
Kevin
It smelt similar, but I have no idea if it is that.
Kevin
I recently bought a very nice second hand Rega Planar 3 ( thanks hifi Dave ) and wasn't sure if the bearing had been serviced so I decided to change the oil. Firstly I used Audio Origami oil and thought the sound was a bit 'thin' I then went on to Youtube and it seemed that car gear oil seemed to be recommended for this turntable. I had some in the garage so used that and it seems to work perfectly well.
When I had a GL75 I discovered that the type of bearing lubrication used had a large effect on the speed and sound of the turntable. Grease affected the speed stability and thin oil affected the sound quality. In the end I settled for car engine oil. I would use what's recommended by your turntable manufacturer if possible.
Regards
Brian
Amplifier : Sony TA FB740R
Speakers : Tannoy 637
Slick 50 may not work out cheaper, as you would need to add oil to it as well.
Kevin
Did they use it with oil?
Kevin
