Having the upgrade bug I took the CA640P to the next level so to speak.
I put in op amp sockets and some audio friends and I experimented with different op amp combination's and at the moment have settled on AD823's in the input stages and LM4562's in the output stages. I also put in polystyrene bypass capacitors on the op amps instead of the lowly ceramics.
It's a match made in heaven and there is simply no comparison between them and the stock units, they can be done cheaply and quickly. It was compared to a well respected valve phono preamp costing a LOT more and it beat it hands down, the valve preamp was quickly sold and the upgraded 640P now in it's place. It was also compared to a high priced solid state phono stage with exotic components and not only held it's own but was found to be superior in a few areas.
![](http://i729.photobucket.com/albums/ww297/Hypnotoady_photos/Jim640P.jpg)
I suspect that CA had a good design but the bean counters dumbed it down with cheaper components or the manufactures in China are substituting components.
If anyone wants to give it a try I can list all the components that I use.
Phillip.
Records... the Vinyl Frontier. These are the voyages of the turntable Perspective. Its five-year mission: to explore strange new records, to seek out new artists and new sounds, to boldly go where no hyper elliptical diamond stylus has gone before!
Polk Audio SDA 1C + Yamaha C4 / M2 + Custom Made DIY Phono Stage + Pro-Ject Perspective + Pro-Ject Speed Box II + Benz Micro Ace = Magic.
