Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Rega older RP8 or latest P6?
    I'm simon.
    Default Rega older RP8 or latest P6?
    after going round and round in circles (no pun intended) trying to decide on an upgrade path from my modded RP3, i have finally got it down to a choice of 2.
    the older RP8 that still has the outer plinth and hinged lid or the latest version P6.
    just interested on views of which one to go for?
    DIGITAL:flac/pc/foobar/wasapi>Chord Qutest> Frans' (Solderdude) headphone correction filter>Violectric V200>Senn HD650, Beyer DT1990
    >or Garage 1217 Project Ember (as pre)>Rega Elex-R>Dynaudio M10.
    ANALOGUE: Rega P8>Rega Aria> Rega Elex-R>Dynaudio M10
    Probably depend on rest of your system to an extent, and what it'll sit on and where.
    I'm simon.
    the deck will be on a wall mount. speakers also on wall brackets.
    my, very modest, system is listed in my sig.
    its a fairly small room i listen, unfortunately.
    They say to keep regas away from speakers so as long as the wall is solid and speakers are not too close should be ok.
    I'd be inclined to go with the rp8
    I'm steven.
    I have a rega rp8 no brainer very musical deck and can handle high end cartridges if you want To go the upgrade route although I just use the rega ania cart
    I'm simon.
    my budget went out of the window, as usual.
    currently home trialling P8 with ania-pro.
    The only audible difference will be the echo in your bank account.
    There's a big performance gap between the old RP3 and the latest P8. You won't be disappointed.
    I'm simon.
    you are dead right, i am not.
    part- exed the rp3 in and now own the P8/Ania-pro and its superb!
    Well done.
