I have a Micro Benz LP-S and can vouch that it is a super, super cartridge, the difference between a cartridge like this say a £1K Hana, or Phasemation PP-200 or PP-300 is quite a leap (not that any of them are bad cartridges). I have tried the Hana SL and PP-300 at home.
Another thought you might want to consider a Phasemation PP-500 which at just under £2K is reported as an exceptionally good cartridge, and if anything like the PP-300 will be very good. The owner at
"https://ammonite-audio.co.uk/" is a great chap and used to loan some cartridges out, so could be worth giving him a call.
I also have a Michel Cusis which is actually a Micro Benz Wood S(I believe) in a composite body made for Michel, this is also an excellent cartridge, not quite the same level of detail and refinement as the LP-S, I would say equivalent in SQ to a PP-300.
Not knowing what you have, another thing to consider is how good your phono stage amp is, if you enter the world of the +£2K cartridge, don't assume your phono stage will be up to the job, it will sound better but you might not get everything the cartridge can extract. I have used 4 phono stages with my LP-S and I was quite surprised at how detail I had been missing when I purchased the current one and also the same with on-board phono stage in my Krell pre-amp.
I got back into vinyl 8-9 years ago, and started out with a used Pro-Ject Experience II, Ortofon Rondo Blue MC and Camprbridge 540P phono amp from a friend all for £600, this has evolved into the vinyl replay set up that I have today, it cost in the order of £10K, that's Cartridge, Phono-cable, turntable and phono stage, a lot of money really, but you could easily spend 2 or 3 times that and not hear much improvement. I went through 2 other turntables, 2 arms and 4 phono stages. A friend uses an LP-S with SME 20/3, SME V arm, £1K of cable, and a £13.5K phono stage, if brought new about £30K outlay. IMO opinion it may only have very slightly more detail/depth, but it is very subjective. So it can be a slippery and expensive slope but if you get it right for your ears can be very rewarding.
One another note you mention 'on an item (with a relatively short life)', there is a great deal of pooh written about cartridge and stylus life IMO. I believe Ortofon say that a well cared for stylus that is regularly cleaned before playing records and is used on clean records should last at least 2000 hours or more, several other manufactures say similar. I know of several people who have sent cartridges off for inspection/re-tipping to manufacturers at around 1000 hours and they have just been returned being told that there is nothing wrong with stylus or cartridge. If you consider an LP is generally 40 minutes long then if 2000 hours use is the limit this is the equivalent of playing 3000 albums. So even playing 2 LPs a day, every day of the year it should a cartridge should be good for 4 years, which is not terrible. I suspect most people will struggle to play 500 LPs a year.
I hope my ramblings help a bit, vinyl replay is not easy to get right, as I found out.
