Results 1 to 3 of 3
Thread: Wanted PTP kit
    I'm gerald.
    Default Wanted PTP kit
    Looking for any version of a PTP kit for a Lenco on a tight budget hence going second hand .
    Regards Gerry
    I'm Neil.
    If you haven't done so already you should check the lencoheaven.net website as they often come up for sale on there. If you join up you can put up a Wanted post which should elicit some offer..
    Neil.
    Quote Originally Posted by diviy View Post
    Regards Gerry
    You might want to state which version your after.
    PRE
