Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Sony TA5650 Vfet & ST3950 tuner
    Get yourself one of these and use a conventional Belling & Lee aerial plug.
    https://www.amazon.co.uk/Connector-S...7Z4CLT9N&psc=1
    (According to a radio ham friend of mine, F-connectors are so called because they're F - ucking useless! )
    Thanks Barry
    Well I’ve now got the Sony hooked up to the B&O’s and it’s doing a pretty good job , the Roksan still has the edge by a small margin imo .
    That's a very good shout Barry, yes F type connectors are the spawn of the devil.
    Andy, sometimes F type connectors are difficult to locate on the thread initially. Once done up they have to be'nipped' to make good RF contact.
    Horrible things.
    Horrible things.
    Done it now mate , with the f type plug I can’t get any stations in stereo but without the plug and just the wire poked in and the wrapped around the thread I then get stations in stereo
    Now they’re a little tight in there so a silent fan may be on order
    Do you realise that the F type has no centre pin?
    The inner conductor from the coax has to be cut long to form the centre pin, it can be bent and shorted whilst trying to mate with the socket.
    As I said horrible things.
    Ah ! Maybe that’s where I’m going wrong, I have it too short I reckon.
    Thanks Alan
    yup they are really used as emergency plugs, or were...but if you set one right it often works for years
    should add you can get the f plug to coax adaptor. it screws into unit and leaves a coax type socket
    Yes, that is what I suggested: https://www.amazon.co.uk/Connector-S...7Z4CLT9N&psc=1
