Results 1 to 10 of 13
Thread: FS - Joe Henry pass labs aleph 3 class a power amp clone
    I'm Philip.
    Default FS - Joe Henry pass labs aleph 3 class a power amp clone
    Joe henry built to higher spec than his usual excellent offerings.
    Collection from eton wick, near Windsor.
    It owes me 680. So -
    £680.
    Or a deal against an audio innovations 700/800.
    Photos to follow.
    Dimensions
    50cm Wide
    40cm Deep
    22cm High
    Speaker protection
    Dual toroidal transformers
    Dual 50 amp bridge rectifiers
    Dual power supplies
    160,000uf Elna capacitors
    Double-sided thick gilded PCB boards
    Power Soft start circuit
    Blue LED on/off switch
    Input differential Transistors using the new US FU9210
    DC blocker
    Precise matching mosfets
    Supply rail fusing
    XLR balanced inputs
    RCA inputs
    Audio grade binding posts
    SPECIFICATIONS
    Gain 20 dB
    Freq. Response - 0.5 dB at 2 Hz, 100 KHz
    Power Output 30 watts/ch 8 ohms
    60 watts/ch 4 ohms
    60 watts/ch 2 ohms
    Maximum Output 23 volts, 8 amps
    Distortion (1KHz) 0.2% @ 30 watts, 8 ohms
    1% @ 60 watts, 4 ohms
    1% @ 60 watts, 2 ohms
    Input Impedance 23 Kohm
    Damping factor 100
    Crosstalk > -80 dB 20-20 KHz
    I'm Philip.
    Beautifully built Nelson Pass design, and given the quality of construction a bit of a bargain. GLWS
    Hi
    How old is this amp please and could you detail the improvements that make this a higher spec? Also how hot does it get with prolonged use?
    Thanks
    Chris
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    I'm Philip.
    Hi
    Thanks
    Chris
    I was going by the actual size of the unit and cooling fins, and the dual toridal transformers.
    I have written to Joe Henry or clarification of spec and age.
    For me, it only ever got warm, never hot.
    I'm Philip.
    There was another joe henry aleph 3 sold on the se forums in 2019.
    Smaller case, one toridal trabsformer.
    https://theartofsound.net/forum/show...-Aleph-3-clone
    I'm Philip.
    Hi
    Thanks
    Chris
    pm sent with reply infor from Joe Henry.
    I'm Philip.
    I emailed Joe Henry for further info about this amp.
    It is indeed higher spec than normal.
    He stated -
    'This was built in october 2017. It was not the standard build.
    This was built with good separation of the channels in mind.
    Hence 2 toroidal transformers
    2 Power supplies.
    4 50Amp bridge rectifiers (2 each channel)
    Speaker protection
    Soft start module
    EMI filtering
    DC Blocker Module
    You could say 2 monoblocks in one casing.
    One picture Attached.'
    This is a bargain.
    I'm Philip.
    up
    I'm Philip.
    Really enjoying this so withdrawn.
    Sounds wonderful.
