Results 1 to 8 of 8
Thread: Is there such a thing as an in-line amplifier protection circuit?
    I'm Alfie.
    Default Is there such a thing as an in-line amplifier protection circuit?
    I have a Sugden A21a Signature and a Croft RIAA Phono Stage.
    Both Glenn and Sugden have said that if the Sugden is turned on first, I risk damage to the amp (and possibly my speakers) when I turn the Croft on.
    I understand the concept of source first at power on and amp first at power off, but I have a wife and kids and we all enjoy the music... I don't really want to stop my family from listening to music on my system, and even if I did, I won't always be around to police it.
    Before his passing, Glenn was kindly going to install a protection relay circuit in the Croft, but sadly that's no longer possible. He was going to do this free of charge, which is the kind of man he was.
    With that not being possible, is anyone aware of an in-line device I could put between the Croft and the Sugden to protect the Sugden? Or perhaps if that's not possible, if there are any other folks who could put a protection circuit in the Croft RIAA for me?
    Does anyone else live with this issue and found a way to relax about it?
    Cheers
    Wow, I did not know this was a thing - when I switch on, I do it in vertical order, starting at the top (T/T power supply, CD player, amp, phono stage). Never gave it a thought. Till now.
    the rule of thumb is to switch on in the direction of travel of signal, and then the reverse for off..
    @Alfie. I have fitted muting boards to phono stages that I have built in the past, I have a couple spare.
    I could fit one to your Croft if you wish.
    @Steve. A lot of modern SS amps have a start up delay before the speakers are connected, so generally there are no problems.
    Usually it is only with valve phono or preamps that perturbations can happen on the output before fully warmed up.
    (Note the big word for a Saturday).
    Well I've learned something there, and that is what I will do from now on. How about you Alfie, think your kiddies will remember that?
    I'm Alfie.
    @steve - Still carries too much risk for me I think
    @firebottle - That would be great, thank you. Please can you send me a PM with a quote? The ideal would be for the LED to be red when the muting circuit is on and turn green when it’s ready for use. This is how it is in the 25 preamps.
    Cheers
    My preamps (including the RIAA) are powered up all the time, but when switching sources (tuner, CDP, turntable etc.) I always turn the volume down to zero before switching them on or off.
    Otherwise what you say is perfectly correct.
    I'm Ian.
    I use a kramer switch to swap front channels between my av processor and valve pre amp. No cross channel pollution. I can listen to av then power up the pre amp and when stabilised swap to music by switching the input. No noises at all. Guess the same would work on pre amp inputs
