Caig Deoxit. At 20-odd quid a tin quite pricey, but I suppose it goes a long way.
deoxit is the berries and a can will likely last a lifetime. its great for cleaning and good for lots of things. it improves the intermittent connections etc. super for removing oxidization too.
probably the best buy you can make in audio.
dunno if its what you require tho. probably need to open it up and see if it looks damaged etc. fit another pot and it'll likey be fine for another 10 yrs
Even though Sugden may have a long waiting list for service and repairs, if you can find the pot is the issue, perhaps they could just send out the part quickly for you to have the work done elsewhere.
Is it remote volume?
Cheaper to sort then anyway.
Now the on/off buttons fooked!
Oh dear you're not having much luck with it.
