Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Castle Severn 2 floor standers light oak veneer
    I'm Stuart.
    done a couple for you
    Hi Grant
    Thank you so much.
    I really appreciate it.
    Not that I’m likely to have any hifi kit for sale over £250 in the future but if you have time to give me a couple of pointers as to what I should be doing, then that would be great.
    Thank you
    Stuart
    Quote Originally Posted by MisterMoseley View Post
    Hi Grant
    Thank you so much.
    Thank you
    Stuart
    sent you a pm..
    I'm Stuart.
    sent you a pm..
    Thank you
    I'm Stuart.
    Weekend bump and price dropped to £250.
    I’ll also include the spare tweeters (immaculate and measuring OK) and spare crossovers in that price.
    Thanks
    That's a lot of very nice speaker for the money, especially with the spare parts. Somebody should grab these. Good luck with the sale.
    I'm Stuart.
    The cabinets are immaculate and as close to mint condition as you are likely to find on a pair of legacy loudspeakers (manufactured around 25 years ago). Made in the UK by Castle in Yorkshire - well known for the quality of their cabinet making. These are as much pieces of furniture as they are speakers. I would describe these as small floor-standers.
    There is no ‘sun fading’ to the wood which you so often see when speaker grilles are left in place.
    In my opinion, these speakers produce a (slightly) warmish sound. I would call them relaxed and certainly not "bright" sounding. I've used them with vinyl and various iterations of digital. I can listen to them for hours without feeling any fatigue on the ears.
    They are currently being used in a second system.
    Technical;
    47Hz - 20kHz
    8 ohm
    2 way speaker
    25mm composite soft dome tweeter.
    150mm bass/mid range unit - carbon fibre.
    Sensitivity - 1w/1m @ 87dB
    Dimension; 770mm tall, 200mm wide, 230mm deep
    I currently have them connected to a 35 watt digital amp and they perform beautifully.
    In my main system, they’ve also been happily running with a 50 watt Rega Brio amp.
    Some very light 'crazing' to both tweeters which I've been told could be re-doped to return to A1 visual condition. Both tweeters measuring 6.5/6.6 ohm but I haven't measure the woofers.
    I do have the boxes but haven't taken photos.
    These are collection only (Gloucestershire) although I would be prepared to meet up along the M4 corridor, between Chippenham and Newbury (subject to prior arrangements being made).
    Asking £275.
    Thanks for looking.
    Thanks Geoff.
    I appreciate the vote of confidence.
    I’m not going to drop the price again and if I can’t achieve £250, then I’ve decided to keep the Severns and instead, offer up my Castle Avons. These will be a far bit cheaper and although the drivers are vgc, the cabinets are only average.
    Stuart
    I'm Stuart.
    I’ll give these one final bump and if still no interest, then I’ll probably pull the ad and try again next year.
    Thanks
    I'm Adrian.
    PM sent Stuart
    I'm Stuart.
    PM sent Stuart
    And replied Adrian. Thank you.
Tags for this Thread
