Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: How to scare “sangliers” (wild boar) away from your garden?
    I'm Kevin.
    Default How to scare “sangliers” (wild boar) away from your garden?
    Winter is coming, it is getting cold, so the local wild boar have decided that my garden is a good place to look for food.
    These are not animals I want to come face to face with, as they can weigh up to 150kg.
    Does anybody have experience of stopping these beasts getting in fields/gardens?
    I am thinking that an electric fence may be needed?
    Kevin
    electric fence should work. my brother had one at his place to keep the animals in their fields etc. boar also dont like loud noise so maybe setting up a triggered alarm etc might work..
    edit.. wolves sound would maybe scare them away... would work for me
    perimeter minefield with concertina wire barrier.
    you need thick hedges, preferably thorny/ prickly type. Or a wall.
    12 Bore?
    PRE
    I'm Kevin.
    Quote Originally Posted by Wakefield Turntables View Post
    12 Bore?
    I have a 12 bore “available” as well as something more accurate.
    I don’t think the neighbours will be too happy with me discharging firearms in the middle of the night though.
    Kevin
    Find out what local farmers use, they'll have it figured.
    Downsides - Might be a bit pricey.
    I'm Kevin.
    Kevin
    I'm Kevin.
    It is/they are coming in from a farmers field. I don’t think he has it sorted.
    Kevin
