As per title.
Thanks
As per title.
Thanks
I'm Colin.
I'm Adam.
Hi Phil,
About 6 years ago I inherited a Unison Research S6 amp from my late uncle.
He had a set of 6 of these valves in it. I think that they came from Watford Valves.
After about a year one of the valves red-plated and I took the whole lot out because he also had another set of different EL34 valves which I put into the amp.
So, I have a set of 6 (one of which is dead) out in my garage doing nothing at the moment.
I wish there was a simple way of getting them tested to see how good they are now. As I said up above, I only used them for a year.
Let me know if you are interested in discussing them any further
I'm Adam.
I managed to find this place in Edinburgh:
http://www.timetravelaudio.co.uk/ser...ing-servicing/
If I get all 5 of them tested and they are all of a suitable quality would you be interested in buying them?
I'm Malcolm.
If you are still after a Quad of these I bought some from Hotrox back in Feb 23 but I have sold the amp on now. I reckon around only 30/40 hrs use on them. I doubt you will find a better price than Hotrox anyway for these rare and wondeful sounding valves. A clear difference over EH Tungsol etc only Gold Lion can compete.
£160 for the 4 I will cover post UK only.
Hi,
That's a good ptice.
I'm actually sorted and using mullards.
But thanks anyway.
Sold
