Originally Posted by
Pharos
Coincidentally my alarm clock fell two days ago and the face cracked.
I did my best to deform it and get superglue into the cracks, but with limited success. It never did polish well and was always a bit cloudy, presumably cheap plastic.
I used Brasso Silvo, (finer), and Duraglitwith very limited success..
Usually plastics will respond to a series of wet or dry papers, 4 or 600 upwards towards the finer 1200 and 2000, and then the use of a polish as above.
Finishing with a polymer coat; Simonise Diamond is good.
Be honest, you chucked it across the room Are these lids made of something different these days? The cover for my record player is described as acrylic.
